Yesterday i installed from Vaio Update program WinDVD BD 8.0.20.169 after finishing the update it restarted my pc and then asked to update WinDVD BD 8.0.20.89 a previous version that i already installed a while a go. I tried to install it but it said that the update failed Error Code 0xA0011000..... why the vaio update shows as available update a previous version of windvd? what is happening?
My vaio is a VGN-FW51JF..... ANY REPLIES? HAS ANYONE THE SAME PROBLEM?
THANKS IN ADVANCE!!!!!!!!!!!
Hi Dimkatsa,
welcome to Club VAIO..
There has been some strange problems reported with Vaio Update 5 over the past few days and they appear to correct themselves after a day or so, occasionally a system restart can help..
If the previous version of WinDVD BD does not disappear from Vaio Update then please post back and will see if we can help further..
You are right the windvd old update disappeared today....
Thanks a lot for your help!
You're welcome dimkatsa..
This post actually fits naeatly in with another 'VAIO UPDATE 5 SHOWING WRONG UPDATES.
