All links to information pages in Vaio Update returns a 404 error of page not found.
Example:
http://support.vaio.sony.eu/computing/vaio/downloads/info/en/EP0000310293.xml
Hi troglo,
Can you please give us more info on your laptop model and what you were trying to access and I'll look into this.
Thanks,
Drew
Hi troglo,
welcome to the Sony User Community Forum..:smileyhappy:
As Drew has said a Vaio model & more information on what you are trying to do & how, etc. would be useful..
In the meantime have you checked that your Vaio has the latest version of Vaio update installed.?
Normally you can check what version of Vaio update is currently installed by right clicking on the Vaio update icon & clicking on Version..
You can download the latest version from your vaio models support site just enter your vaio model number into the following link Vaio support site then click on the Downloads tab..
Thanks for the answer, here is additional info:
Sony VAIO Pro 13 with Windows 8.1
SVP1321C5E
Vaio Update software is updated
Country is Spain and language used is spanish
The error 404 happens when trying to get more info from this error in Vaio Update software:
Is there something to do about this issue?
I I have it since 6-7 months already on a SVE1712V1EB.
It shows ''whait a while then try again'' and when you try to do it manually by clicking the update it shows an 404 error page.
