I don't know if I do have a problem, but after having VAIO Update 3 for a while, for other reason, had to do a Recovery - and although I am all there with the usual updates etc.... have been waiting for the VAIO Update 3 to install as the next logical step and it has not. Where can I get it from? Anyone Please?
ps Had a look around but cannot seem to find it on support links!
I try to install vaio update 3 in my vaio FE31M and the software crash - unable to finish the installation. I send the report to sony.
Did anyone face any problem with the installation?
I can't get anywhere with this! When i click Vaio Update 2 from All Progs or click the system tray, all i get is the website saying "sorry - under maintenance - please try later".Anyone got any bright ideas.
At last it worked.
Thanks for everybodies help
Pinching from "Hubby Dubby" worked a treat! Thank You!
!rose.gif|___jive_emoticon_name=rose|jivemacro=emoticon|class=jive_macro jive_emote|src=rose.gif!
And all looks as it should! !tongue.gif|___jive_emoticon_name=tongue|jivemacro=emoticon|class=jive_macro jive_emote|src=tongue.gif!
!cool.gif|___jive_emoticon_name=cool|jivemacro=emoticon|class=jive_macro jive_emote|src=cool.gif! You're welcome VaioWoman1... !happy.gif|___jive_emoticon_name=happy|jivemacro=emoticon|class=jive_macro jive_emote|src=happy.gif!
At last it worked.
Thanks for everybodies help![]()
Glad you've solved the problem eagle-eye..
Hi spirosg
Are you able to download the Vaio Update 3 file again..
I found it and I will download again. hope to work this time.
The problem still exist the program crash.
