I'm thinking about getting a U71, which is only available in Japan. I've found an importer, but want to know if anyone else has got one & what they think of it.
"I used to be indecisive, but now I'm not too sure."
2,5?
My Vaio was died after 1 hour.
But my Vaio is faster.:smileywink:
I think a real Tablet PC is better as a U71. But that's my opinion.
I was very very tempted to buy a U71 but compromised and got the TR5 in the end, which I am very pleased with :smileygrin:
William
Yeah tavlet PCs are cool
Dynamism say that only the Sony Firewire DVD drive can be used to boot from should you ever have to use the recovery disks. The Optical Drive is the same that ships with the X505, so if you've got one, then great, if you havent then a further £169 (DVD-R) or £229 (DVD-RW) might be an essential extra - things soon add up!
I like the idea of using it to surf the net on the move, but there's no mention of built in Bluetooth
so a USB dongle would be needed for Mobile Phone connectivity. No built in 56K modem is a drag too, so WiFi or a CF modem would probably be the best alternatives.
All of that considdered, I am still very interested in getting one
and it's made even better that I won't pay VAT - Pehaps I should buy a few and sell others to fellow Club Vaio users
I think Sony want more and more people to use WIFI to connect to the net now.
2 and a half hours is respectable.
Good luck in finding something that can do > 3hrs
I have. The X 505. But thanks anyway
Really, thats cool [8)]
