Hi all, I noticed that my vaio SZ3 keeps overheating - I downloaded a program called notebook hardware control and it very often, the 80c temp. warning comes up... it has a T7200 CPU which runs @ 2GHz... I have 3GB ram in it and I don't even strain the computer as the only pages I have open are 2 tabs in firefox! Do you guys know if this 80c is a fairly normal operating temp for this CPU or should I get some thermal pastes?
Also, do anyone of you have the VAIO SZ3XWP recovery CD I can nick? I'd appreciate it if I could have a copy/ you can upload it to my server as I have several drivers missing
For sure is overheating...
Actually, you really needs to take a look about what's going on...
The CPU start normally around 38°C degrees and stay at 48°C degrees with normal use like you described.
Normally, I use the EVEREST Ultimate Edition to check my computer.
Can you activate the TASK MANAGER and see which softwares are running ?
Have you your laptop with the original OS software installed ?
Did you observed if this happened after to install a specific software ?
You can download the Original XP Drivers and the Original XP Utilities from here: -
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&c=0&s=VGN...
Check that you have the Power Managaement Utility installed.
Also worth checking that dust has not blocked the cooling vents.
If you want a .PDF copy of the Sony Manual (Simple Version Only), PM me your e-mail address and I will send it.
