Hello! I own a Vaio svE1513c1ew and i want to replace my dvd-rom with an HDD caddy..my question is , i need a 9" or a12" caddy??
Hi VasilakisTs and welcome.
The SVE15 and SVE17 models appear to use the 12.7mm HDD Caddy.
The SVE14 models appear to use the smaller 9.5mm HDD Caddy.
OBHD-SATA12
http://www.newmodeus.com/shop/index.php?main_page=product_info&cPath=2_39&products_id=518
OBHD9-SATA
http://www.newmodeus.com/shop/index.php?main_page=product_info&cPath=2_39&products_id=513
Check for compatibility with vendor when ordering.
OBHD-SATA12
OBHD9-SATA
