Recently re-formatted my Vaio VGN-FW21L and have found the producy key for Microsoft no longer works for Office/Word.
Has anyone else had this problem? Does anyone know how to fix it? As usualy Vaio's help defies the word 'help'!!
Thanks
Dave
Hi Dave,
who did you purchase your version of Microsoft Office/Word from.?
Sony, comes with th vaio with product key underneath the Vaio
Are you referring to the Windows 7 product key on the base of your Vaio.?
If so this is a Windows 7 Certificate of Authenticity code issued by OEM companies & would not work with Office.?
Did you purchase a copy of Office/Word from Sony or was it per-installed.?
Whatever came with it, the product key thats on the laptop worked on it previously, now since re-booting it doesn't.
Hi DemonDave,
do you have more than one sticker/product key on the base of your vaio..:smileyconfused:
Usually Vaio models are sold with Office trail pre-installed - How to activate your 60-day trial version of Microsoft Office 2007?
If you suspect that the sticker on the base of your Vaio was an activation code for the copy of Microsoft Office/Word that was pre-instaled then all I can suggest is that you contact the official vaio support team for further advice..
I have one sticker on the bottom. I have already contacted them just awating a reply.
Whatever Word came on it previously, the key on the bottom worked with it, as I ran Office on the unti for close to 5yrs before re-formatting it.
Thanks Thalamus
Thanks Thalamus
I would be interested in knowing the outcome, could you please keep us updated.?
Willk do bud
