I HAVE NOTICED THAT EVERYTIME I PRESS THE VAIO LINK(THE ONE THAT IS DIRECTLY OPPOSITE TO PROGRAMS ) IT OPENS BUT DOES NOT SEND ME TO THE PAGE AS IT USED TO.CAN SOMEONE HELP?THANKS
Why not just open IE or FF and type in www.vaio-link.com?
It's just a shortcut nothing special
Well what more can I say? It's not hard to type in www.vaio-link.com is it?
Stop shouting too
Try this port linkhere . It might get you in without waiting half an hour which it does??? sometimes.
It's funny how their design hasn't continued on that page
Carelino,
I may be wrong here but I thought that was what the VAIO Update balloon in the task tray was for..:smileyhappy:
See the text from Vaio Update below:-
VAIO Update provides you with a selection of updates available for your VAIO computer and alerts you to critical issues such as computer viruses.
When it appears, click on the VAIO Update balloon in the task tray. Your web browser will take you directly to the VAIO support web page for update information and important warnings.
