I accidently deleted the e icon from the vaio gate how can i get it back?
Right-click on the 'Start' icon and click on 'Open Windows Explorer'.
Navigate to C:\Program Files\Internet Explorer and in that folder you will see iExplore.EXE.
Right-click on iExplore.EXE and choose 'Create Shortcut'. You will see a box asking you if this should be created on the desktop - click 'Yes'.
Close Windows Explorer and you will see a new icon on the desktop labelled 'shortcut to IE'.
Simply click on the new icon and drag it into the Vaio Gate area.
