Just bought Sony T1311 ultrabook but have a problem with vaio care which support don't seem able to solve.
When I open it I get message that the shell has stopped working and Vaio care closes. Support asked me to re download .netframework but it hasn't solved the problem. has anyone any clues as I think others have had similar problems? Thanks.
Chris
Hi Chris.
Sadly this is a known problem and we are assured that Sony Support are still working on a solution. You can look at the main discussion here: -
http://www.sony-europe.com/discussions/thread/163033?start=45&tstart=0
Hi Chris.
