I have a V2S.
When the V2S starts a program called VzFW.exe runs continuesly and makes the hard disks working non stoping.
This program never stops and also the hard disk.
When i stop the program with the task manager all is back to normal.
Could anyone tell me how to solve this problem.
My email is [email protected]
If you don't use Vaio Zone then the easy solution is to run msconfig and stop the program running at startup.
If you do use it then make sure you have installed all of the updates from Vaio-Link
