Following the difficulties I have been having trying to get a USB audio device to work on my PCG N105 I have decided that it is abouttime to use the Product Recovery CD-ROM's.
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=33855
I am a little teriffied as I have some very useful programs that I don't want to be messed up and have yet to do a full backup.
Any recomendations as to the best backing up procedure and things I should be aware of...
I am assuming that the recovery disks will not over-write everything else on drive C:
Best Wishes and thanks for your time,
Steve
Two ways you could go here.
1) if you have an external hard disk, or connected to a wired LAN, you could make an image of your hard disk, with something like Acronis TrueImage. This will backup EVERYTHING, it's like someone's made a twin of your hard disk.
2) You could use the file and settings transfer tool in Windows - Start > All Programs > Accessories > System Tools > Files and Settings Transfer Tool. This will back up email, internet settings, application specific settings and files which you've selected. Long winded, but it's not a bad route to go - personally I'd go for 1.
HTH
