Hello
Drivers installation are needed for connecting the XT1
no cd with the box
installation on 3 workstation with no cd asked
But with my Fe21H: cd asked
Any solution
thanks
drivers are on local disk c:/driver
when asking for drivers search into this file...
maybe i am wrong...if i don't understand.
thanks but ...
i've dl the new drivers for the FE but always the same
the xt1 is a usb system
i can change the volume with the xt1 but no sound
is it possible to receive the windows cd with the vaio ???
it seems to be the origine of the drivers problem.
there is no windows CD delivered with a Vaio.
The windows CD is on the HDD folder /windows/i386
same problem with logitech V20 (usb speakers)
no cd necessary : except for my vaio ???
any solution in the world ?
