Hello,
First, excuse my poor english, Im french...
I have problem with my AR11S : I can only put 2 USB device on same time. When i plug a another one, first I loose the buildin camera and after i have a message "unknow materiel..."
I have try with USB Hub, with USB key, USB Harddrive, printer...
Some help ?
Laurent
Is your USB hub powered by the mains?
Est ce que votre hub USB est brancher au courrant?
Yes, it's the same powered or not.
May be I find the solution : after installing the MS drivers for the Ehome for Win XP, the USB port works better. I can put 6 USB device without problem. But I must plug the USB device one by one... Better but not fine.
