Anyone got any suggestions for which one of those flexible USB lights designed for laptops to choose? There's so many available it's impossible to know where to start or what to look out for.
I would not recommend u any.
They suck all too much power from the usb....might be dangerouse to damage ur mainboard.
Only those with LEDs i would buy.
They consum less power and have a longer life.
cheers,
I would suggest getting a battery operated one, saves USB power.
I use one, I bought in Shanghai. Don't know the particular brand. But there isn't a dramatic impact on battery life as some would think. It is actually very handy since the keyboard on my laptop is black.
Yeah it's hard to see in the dark
