I'm currently looking for a USB digital tv tuner. I also want to use it as a video recorder to capture some old family videos and stick them onto DVD. I'm currently looking at this one:
Hauppauge Digital DEC2000-T
Have you lot got any suggestions?
Oh An easy one here ...........
Sony VTX-D800 This works very well for me , I would think it would sit very nicely next to any PC . But A VAIO well , its made for the task ...." Five Star * * * * *" I rate This Item , many months of happy use , in the past .
Why use your usb when other stunning options are open to you ?
Cheers Psaila
One thing, it won't connect to my Vaio, thats what the usb is for.
Ah, is smartlink the same as firewire I-S400?
Hauppage gear is normally pretty good, the only other one I've found is http://myahead.com/go/look/product.show_product?v_id=8528
Smartlink isn't a PC interface . . . . it's for connecting to TVs and Video recorders and has (I think) something to do with autosetup.
Many thanks Rob , theres one I had not seen .
Why are there so many problems linking Sony product's , I'm a loss at the problems encoutered by so many trusting Sony User's Who buy Sony products, that you would feel would link to each other with out a second thought , What Happend SONY ?
No problem Raymond, I wouldn't normally have butted in but I wouldn't have liked Induct to have bought the Sony box only to discover that Smartlink isn't a PC interface . . .
We all make mistakes . . . . retirement isn't the solution. You have lots of friends on the board (me amongst them I hope) and we enjoy hearing from you.
