Hi everyone,
I was hoping someone might be able to offer some advice on whether it is possible to upgrade the RAM on the following laptop ?
SVF1521P2EB
To be honest, for a casual user - internet, film, music,itunes, PS etc I thought 4GB was going to be sufficient for my needs - however, I am shocked by the laptop's ability to multi-task when compared to my previous Asus X53E with 6GB of RAM - the performance is so bad I am regretting the purchase - it is very frustrrating.
I would love to upgrade to 8GB or even 12GB if possible - can anyone point me in the direction of where I could buy RAM for this laptop and even if it is possible at all ? Furthermore, does upgrading RAM default the 1 year warranty ?
Thanks a lot in advance for you assistance.
Hi jgn1982,
welcome to the Sony User Community Forum..:smileyhappy:
According to the SVF1521P2EB specifications your vaio has 4GB of RAM..
Crucial.com's memory advisor, a forum favourite supplier, states your Vaio can support a maximum of 12GB & recommends the following guaranteed compatible upgrade
If you want to check this you can also download & run there System Scanner tool
Sony have a guide on how to Add RAM in the user guide - download here , a copy of which is below..
Hi jgn1982,
thanks a lot this is a very helpful reply and website
have a lovely day
do you know whether the processor turbo is turned on as standard ? Asus has a speedo clock that tells you how quick it is processing, without this on the Sony I am never sure if the turbo is activated - it doesnt feel that rapid in all honesty
can anyone shed any light on this ? still not convinced my laptop is running as quickly as it should
i also have this computer and when i opened the back to add the 8gb of memory there appears to be 2 card slots. the bottom 1 has a 4gb card in it but the top has non? am i supposed to put the 8gb in place of the 4gb card or am i supposed to buy another 4gb and put it in the top slot and leave the 4gb thats already in the laptop still in there? or can i put the 8gb in the top slot and leave the 4gb in the bottom slot?
i was always under the impression though that both slots had to match?
any help as sony say this machine onl has 1 slot but it definately has 2.
Hi vauxfan,
I do not believe that there is any 6GB memory modules, therefore if you want matching pairs you'd have to stick with 8 GB (2x4GB) but if you want to have the maximum 12GB of RAM in your Vaio then go with Crucial's recommendation of the 8GB one..
So in answer to your question I would say put the 8GB module into the empty slot..
Sorry missed your second question jgn1982..
There isn't as far as I am aware any option to turn the Turbo processor on or off, Turbo boost basically switches in when demand is needed..
@vauxfan wrote:
So they don't have to match?
No they do have to match & the 8GB DDR3 RAM that Crucial.com recommend should work fine with the currently installed 4GB module..
@vauxfan wrote:
Why is sony only quoting 1 card slot then if it has two?
Can you provide a link to where Sony state that there is only one slot in the SVF1521P2EB because I can't seem to see it..:smileyconfused:
