Can anyone help and advise me on;
a) the maximum memory for this model
b) what Ram to get - i.e DDRII ?
c) what speed - 533 / 667mhz and implications
d) where to get the memory from and how much to pay?
thanks very much
Shayman:smileygrin:
Hi Shayman and welcome to the forum.
Have a look HERE. They state that the max memory for your model is 1GB but this is not correct as you can upgrade to a max of 2048Mb. You could also try Crucial.com - your model is not listed but they should be able to help.
Rich,
you is a top banana
was a tad confused on the matter, but will get shopping now!
many thanks
Shayman
You're welcome Shayman:smileyhappy:
