Hi guys,
I'm looking to upgrade the hardisk of my FS115S but im not exactly sure what hardisk would be suitable.
All i know is il need a SATA hardisk, (i think) and i would like a faster speed disk than 4200, preferable 7200rpm like this below
http://www.allcam.biz/catalog/product_info.php?&products_id=106
Can anyone give me any advice on this?
Also i'd like to be able to directly transfer all the data from my current hardisk to this new one including way my current HD is partioned for recovery etc etc,
How would i go about doing this?
Thanks, Ali
Hi Ali,
According to the specifications of your FS115S, you do not have a SATA hard drive.
You need a (P) ATA drive. The Travelstar 7K100 you have highlighted in the link is an ATA Parallel drive and will fit your Vaio OK. This is a very good drive you have chosen.
Also i'd like to be able to directly transfer all the data from my current hardisk to this new one including way my current HD is partioned for recovery etc etc, How would i go about doing this?
Thanks for your replys guys!
So if i use to Acronis true image to do this Rich, will i be able to insert it into my laptop and then continue as normal or will i have to reinstall windows, and/or reformat so it is recognised as my C:/ drive?
Also what do you mean by considerable? for example at the moment i have an 8OGB drive partioned into two with around 20GB space free in total.
Thanks, Ali
You don't need to touch Windows, it does it all for you
great!
Thx for your help guys, now if only i can find acronis true image for free :?
15 day free trial HERE
