why can't i date load up date's from vaio am useing a vgn-ns20es
got message saying 0008 can any one help
Hi 61967047,
Are you using the original operating system and which version of Vaio Update do you currently have installed – right click the Vaio Update icon in the system tray and select ‘Version Information’.
This may or not be a continuation of the current ‘Vaio Update’ problem as error 0008 would seem to indicated that the program is not functioning as expected.
Below is a link to the current problem:
https://www.sony-europe.com/discussions/message/741675#741675
Here is also a link to an older thread that mentions the error code 0008:
http://www.sony.co.uk/discussions/message/399170
Rich
Hi 61967047,
Rich
