Unable to extract R0232U2.exe told I "sorry you do not have the permission to extract the file" and yet I am local admin any ideas why does the exe have a green padlock symbol on it?.
I have also installed the hotkey utility but the FN keys still do not work.
I have a PCG SRX41P with Windows XP SP1 installed.
Maybe this file is password protect. But i you want install the hotkeys, then you must doubleclick "setup.exe".
But what is R0232U2?
Sorry, I can't help you with an BIOS update, because I have never done this.
Do you have WinZip installed?
Strange that it doesn't work.
Take it you have re-downloaded the file?
Try installing WinZip.
If that doesn't work then VAIO Link need to be contacted.
This may sound a silly question but have you changed the original Windows operating system? It seems the only plausible reason for the file being locked.
