is there anybody out there who has a solution or a hint to the Bluetooth-Problem with my PCG-TR5MP, who is equipped with a nice Hardware-Switch for BT/W-Lan and uses the BlueSpace NE Software.
Unfortunately BlueSpace detects my Samsung D-500 Mobile, but I can't discover any Services. On my Workstation at Home - that uses the usual XP-BT-Software - everything works without any trouble. At all.
Is there an Update for BlueSpace NE?
Is it possible/recommended to throw BlueSpace off the Machine and replace it with the "usual" BT-Software?
What exactly is Life about? (just in case that someone has an answer)
thanks,
Tommy
Hello,
I have VAIO A115S with the same nice switch and SE T630 Mobilephone. After upgrading WinXP to SP2, I don't use Bluespace NE. Bluespace is always loaded in memory what is not really good. Bluespace Ne is remained in my VAIO but I've removed all entries from Run Section.
With "usual" XP-BT-Software I can use my phone as modem without troubles. I can send pictures, games or ringtones, too.
Bluespace isn't very good at all, and your software probably has better handling of your phone
Thanks! SP2 and the usual Software did it. I normally don't do to much Updates because of the "never change a running software" credo. But in this Case it was necessary and useful.
hurra:smileylaugh:
