My sony vaio VGN-FE21B Doesn't Shut down the only way to turn off its to remove the battery or hold the turn on button for 8 seconds plzzzzz help.
I'm not sure if this will help you but i'm certain it won't harm your laptop anyway:
http://www.microsoft.com/downloads/details.aspx?familyid=1B286E6D-8912-4E18-B570-42470E2F3582&displa...
thanks lawrenceuk now my pc its ok :smileygrin:
If you are under Win XP you need an hotfix, kb909667, to fix this problem. This is caused by USB webcam. Install this fix to resolve this problem!
SEE YA!
xman3
