my touchpad has a problem. The mouse was first really slow and now i can´t see it at all anymore..
Message was edited by: hemuli8
Check the control panel of your touchpad and check if it has been set up corretly. You can also check your device manager if your touchpad is still available. You can do a rollback or reinstall its driver.
