I recently downloaded IE9 and Adobe Flash 10.3 to my VGC-JS2E (running Vista)
Since then the text entry size for Id/Passwords on some web pages is very small, fonts seem different and other text eg on Itunes is also very small, existing sreadsheets have changed to small text (although new ones seem fine)
I've uninstalled IE9, gone back to IE8, played around with dpi/fonts/screen resolution but to no effect.I've reset IE also
No text size problems if I use Chrome/Firefox though so the source of the problem is a mystery to me
If it was confined to IE I'd use another browser but other software has similar text size/font problems. I may have to completely restore the PC as a last resort but any help/thoughts welcomed
Sounds like you held control while using the mousewheel and inadvertendly changed the zoom level.
