I used to be able to scroll by tapping the right hand side of the touchpad however i cannot anymore. Is there a setting anywhere?
Thanks
Akhil
Have a look at Start > All Programs > Sony Notebook Setup (or Notebook Control). On the Touchpad tab click Touchpad settings and in the next window go to the Function tab > Scroll Setting.
The exact details may be slightly different for you model.
Hello,
Thanks for the relpy, i go into notebook setup, and click the device tab, and click pointing device and settings but it doesnt have a function for scrolling.
Thanks
Akhil
Strange. Try Control Panel > Mouse. Do you have a Function tab on the Mouse properties window and is there a scroll setting option?
If not go to Device Manager Control Panel > System > Hardware tab > Device Manager. Under Mice and other pointing devices do you have a PS/2 pointing device listed or a Standard PS/2 mouse?
Under my mouse properties it says :
manufacture: Alps electric
status: working correctly
is it hell working correctly
i have no installation cd and can't find a website with the driver for my laptop sony vaio vgn-fs115b:smileycry:
AkhilStyle,
The “Alps wide pointing device for VAIO” may be the correct pointing device for your model but to check you need to find the device ID.
Open System Information (Start > All Programs > Accessories > System Tools > System Information).
Navigate to Components > Input > Pointing Device and look for Hardware Type: PS/2 Port Pointing Device. Next to the device ID you will see a value that should include one of the device values listed below, e.g. ACPI\SNY9009.
*sny9001.DeviceDesc= "Alps Pointing-device for VAIO"
*sny9002.DeviceDesc= "Alps Pointing-device for VAIO"
*sny9006.DeviceDesc= "Alps Film Pointing-device for VAIO"
*sny9009.DeviceDesc= "Alps Wide Pointing-device for VAIO"
*sny900A.DeviceDesc= "Alps Wide Pointing-device for VAIO"
*sny900C.DeviceDesc= "Alps Wide Pointing-device for VAIO"
*pnp0f03.DeviceDesc= "Alps Pointing-device"
*pnp0f13.DeviceDesc= "Alps Pointing-device"
*pnp0f0e.DeviceDesc= "Alps Pointing-device"
*pnp0f0b.DeviceDesc= "Alps Pointing-device"
*pnp0f12.DeviceDesc= "Alps Pointing-device"
As far as I can tell from the Apls Apfiltr.inf file the Function tab should be enabled for all of the above devices, so it may be a matter of re-installing the drivers. You will find them either at C:\Drivers\Touchpad or in the Touchpad folder of the pre-installed drivers download from Vaio-Link.
tractorboy,
Rich912 Thankyou so much for your time and patience! I have re-installed the driver (touchpad) after finally finding it in the pointers folder, CHEERS MATE:smileyhappy:
