Hi, there seems to be no option to swap the function of my laptop buttons. Can anyone help? Thanks
Hi v.i.j.a.y,
Try changing the left button setting to 'Shortcut Menu' and the right button to 'Click'.
Rich
Thank You Rich.... This worked and it was exactly what I was looking for.
Your're welcom v.i.j.a.y.
