Hello
Recently I've bought Sony SVF1521Q1EW laptop with 4GB of RAM.
Is it possible to upgrade the memory?
Also I would like to ask how to turn off the keyboard backlight.
Hi AFCMajke and welcome,
This model has 1 x 4GB RAM as standard and the specifications to not mention upgrading so possibly only has one slot capable of supporting a max of 4GB. This is only an assumption.
http://www.sony.co.uk/support/en/product/SVF1521Q1EW/specifications
You should have controls for the backlit keyboard under Vaio Control Center > Keyboard and Mouse > Backlit Keyboard.
Rich
Rich
under Vaio Control Center > Keyboard and Mouse > there is no "Backlit Keyboard"
Do I need an update? I can't find anywhere to put the Backlight on.
Hi mariejose74,
Are you sure that your notebook has a backlit keyboard? What is the product number?
Rich
