All,
Anyone experiencing this:
I can set up the screen resolution 1920x1080/small or regular icons etc set up my tiles on the Start Screen in 8.1 and all is fine.
Restart/Close Lid & Open and it changes..?
I can go from 4 Rows on the Start Screen to 5 or 6 it varies. On the Desktop the Tool Bar at the bottom is small or large to.
Any ideas or fixes will be greatly received 🙂
Done it...
I had my other Laptop and Flip both on Windows 8.1, with Skydrive sync settings both syncing - caused conflict.
Have disabled both from doing this - fixed.
Nope, but I would first check if your display drivers are okay and the latest ones
actually it's back!
thinking now it's a Windows glitch - updates requied....
