On start up my laptop says SQLITE3.DLL is missing and needs reinstalling but dont no what this means or how it got deleted and how to reinstall it..
Any help on this matter would be Brilliant..
Message was edited by: fleety31
Hi fleety31 and welcome.
This is an iTunes error - have you updated recently?
Basically, the Apple installer has a bug and the SQLITE3.DLL gets put in the wrong folder.
Reinstalling Mobile Me and iTunes can fix the problem but there are quicker ways by moving a couple of files from one folder to another.
If you Google for SQLITE3.DLL is missing, you will see various fixes. I cannot recommend one as I have not tried any - the choice is yours.
