Hi all,is there any way to get sound highter?
Sorry,I got FE11S
With the Videolan media player settings you can produce very loud sound from your laptop. (loud sound can damage speakers)
This player plays really everything (including playing while downloading) and very low on system resources.
The best player i've seen so far!
Hi Sandrini,
Have you adjusted the volume by using the volume buttons, on the left of your Vaio, opposite your power button.
Hi Thalamus, of course my frend
Is the sound quite all the time or just in certain programs?
Have you checked the master volume settings by double clicking on the speaker icon in the system tray?
Check your wave setting in the volume controll, move the slider up to get a much louder sound. I also have a FE11S laptop. It helped a lot with me. Can't imagine you would like it even louder. If you have Power DVD there is setting you can get the sound even louder. Don't forget it's a laptop not a SURROUND SYSTEM :smileygrin:
Hi all, when I´m saying if it is possible to get sound louder, I ´m saying ,if there is a patch or anything to do it.
Carelino, I know that I have a laptop and not a surround system, but I also have a HP laptop and it sounds 10 times highter than FE11S ,maybe because it has an Harman/Cardon loudspeakers.
P.D : be moore frienly please
Regards
Regards
