Sony Vaio VPCEJ2A9E Upgrade to Windows.
Tazzed69
Explorer
Hi All,  New on here so maybe asking a repeat question.
I'm trying to updrade to Windows 10 but i constantly keep getting "1 update Failed" as a result.
Microsoft check says the laptop is compatable and looking through the Sony site (can't find it again now) i found a piece with a table that told me everything on my Vaio passed the test (basic tests i believe).
So my Question is - if this is the case what are the issues and why will it not update?
I realise Sony have decided to not support my model for Windows 10 but what are these issues and are there any drivers from third parties that can be used?
It's very frustrating cos it is a great Laptop that I use for work and home and as such have specialist software on which would be a total pain to get put on a new Laptop along with a big cost for new licences.
Any help or links would be of a great help.
Cheers  P
1 REPLY 1
Jason519
Member
I used a program named Driver Talent to fix driver problems in my Vaio laptop. I think you can have a try. This tool works well for me.
