I have a problem wit my Sony VAIO VGN-A517M notebook. After installing the software: "MAGIX Fotos auf CD & DVD 5.0 deluxe" I can not eject the CD drive with the button. The vaio event service reports after pressing the button on the cd drive, that the cd rom is blocked. It works with eject in the explorer. It does not help to uninstall the MAGIX software. The only solution I found is to perform a recovery, but I want to use the MAGIX software.
Does somebody know, how or where the vaio event service looks for a blocking applications. It is maybe somewhere in the registry, but I have not found an entry yet.
thanks,
Wanki
This is common with programs which make "virtual" drives. If you reinstall the Sony Utilities you should get it back
