I would simply like to know how to upgrade my vaio rc-102 with a dvb-t (tnt in france) card and which can be controlled in the software vaio zone.
Please don't answer me buy an rc-202!!!
THXXX
Hi PartyTiger and welcome to the Forum.
As far as I know, Vaio Zone only operates with the dedicated Sony (Analogue) TV Card. Sony do not have a DVB version yet. I may be wrong, but I don't think the RC202 supports DVB through Vaio Zone but as it is loaded with XP Media Centre, it can probably support DVB with this.
I use an external WinTV Nova-T-USB2 which comes with its own software (so I can use it on my Vaio laptop as well) - I don't really miss Vaio Zone.
There are 2 free PCI slots in your RC102, so you could use the PCI version.
Look HERE
It looks like Sony have done a U-Turn by going over to XP MCE - is this the beginning of the end for Vaio Zone?
Anyone knows the name of the card that's in vaio RC-202 !!!!!!
It's exactly the same as the one you have in your RC102.
Sorry Partytiger - I have just found the full specification for the RC202 and it DOES have a DVB-T PCI Card.
Unfortunately, it does not give the name or type of card in the specs I've seen - just calls it 'TV Tuner Card'.
The RC202 does not have Vaio Zone installed but uses Microsoft XP Media Centre. XPMCE presumably allows DVB-T to be integrated into the main screen.
Apologies!
Shame the RA104 didn't get a DVB tuner
