- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I recently bought a laptop from Currys at the following link -
I am wondering if this laptop has an mSATA slot in case I want to upgrade to an SSD in the future? I put the product number into your support bit but it didn't recognise it.
Any information would be massively appreciated!
MorNando
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have found the manual by running a search in your forum!
http://www.sony.co.uk/support/en/product/SVF15A1M2ES/manuals
It appears there is a Hybrid HDD 750GB + NAND Flash Memory for cache 8 GB.
It doesnt advertise this on the currys website but at least that answers my question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi. Do you have any of these problems? http://community.sony.sk/t5/PCs-Accessories/Sony-Vaio-Fit-Touch-high-pitched-sound-microphone-and-wi...
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, fortunately I dont seem to be suffering like you are.
However, I am an IT engineer and it sounds like it might be either faulty hardware or a driver issue. Make sure your drivers are up to date using the vaio care software and if that doesn't help maybe take it back to the store you got it from to get it swapped out/fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I found the sound on youtube: http://www.youtube.com/watch?v=NSKqlttAp-4&feature=related
I use vaio care software and I've already updated the drivers. The problem is I am not from the UK, I bought the laptop in another country but at the moment I am in the UK.. yeah probably I will wait until December when I am going home.. Anyway, thank you for your response.
