x
alexclabbs
Explorer
Sony Vaio Battery
I was wondering what battery would fit in the Sony Vaio SVE1513C5E i made the stupid mistake of disposing the broken battery before i got a new one if anyone knows the battery part number that would be fantastic
Alex
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
rich912
Contributor
Hi Alex,
I believe the battery that came fitted originally (VGP-BPS26) was 10.8Volt 4400mAh / 6-Cell but the newer VGP-BPS26A is 11.1 Volt 5300mAh /6-Cell. Either is compatible but make sure it is a genuine Sony battery or you can expect problems.
Rich
Go n-éirí an bóthar leat
4 REPLIES 4
rich912
Contributor
Hi Alex,
The Vaio E series uses the VGP-BPS26A battery.
http://www.sony.co.uk/product/vaio-batteries/vgp-bps26a/compatible-products#tab
Rich
alexclabbs
Explorer
Thanks for the reply been trying to find the right battery for ages there seems to be a 10.8v and a 11.1v one does it matter which on i use?
Thanks
Alex
rich912
Contributor
Hi Alex,
Rich
alexclabbs
Explorer
Thanks a lot  i appreciate youre help man!!
