Hi everybody out there!
I am now the proud owner of the V1 the most beautiful, sexy and amazing computer on earth.
I would love to remaster my compact cassetes and LPs by using Sonic Stage Mastering Studio with my V1 but I can't find it. Can you help me? Is it shipped?
It isn't supplied with this model.
So no chance to do an audio restauration? Can I buy Sonic Stage Mastering Studio?
No - you could try something like Magix Audio Cleaning Lab 2004 Deluxe which is pretty good for the price. It will allow you to record from line-in and will do basic declicking etc.
hi simon, if you go to msn, tiscali and other isp,s probably you should be able to find free downloads of demo software or maybe freeware that should allow you to record from any source so you can back-up your collection to cd-r. most of it is time limited so if you don,t have too much to back-up you should be ok.hope this helps
Thanks! I got the Screenblast SoundForge 7 - just great, somehow a light edition of the famous SoundForge software. It's a pitty that no audio tool was supplied with the V1, isn't it? Help yourself and check out:
http://mediasoftware.sonypictures.com/products/soundforgefamily.asp
What is best: You can check out your edited songs directly to a NET MD Walkman!!!
BTW, Did you know: SoundForge is now a Sony Software...?
Yes I did.
I have recomended SoundForge many times, but I didn't know it allowed direct MD access, cool.
Sonic Foundry were bought up by Sony.
