I HAVE A MODEL PCG9RGM I CAN NOT FIND THIS MODEL LISTED ANYWHERE
This doesn't look like a proper model code.
If you go to my computer, right click/properties and in the general tab under computer, check your computer model, what do are you reading:smileyconfused:
Titane
THANKS IT SEEMS IT IS A PCG-K2
THE MODEL NO SHOWN ON THE LABEL IS PCG-9RGM CONFUSING ISNT IT
It is a bit
Dell can you please not write in caps, it looks like you're shouting.
