Hi
I have an RS702 and have, at the moment NO problems :), however, what i wish to to is upgrade my sound card.
I am about to order a set of THX speakers, altec lansing..(mx5021)mmm, and would like to know if I can upgrade my sound card. If I upgrade will giga pocket and all the front/rear panel ports still work audio wise or have sony hijacked this option?
I will try the speakers without a card upgrade but eventually there will be the need to ..just do it..
I know that without a THX card they wont produce the effects required
Cheers..
There should be no problem. The problem could be Sony Software. I don't know whether Gigapocket will work with another Soundcard.
I would say: .............try before buy.
If you want high quality, buy a soundblaster Audigy card.
I have an audigy 2 platinum and its fantastic!
