I have a RX 401(CE) and want to flash the Award Bios to allow more access.
So what's your question? If you're asking how to do it, it can't be done. Flashing the BIOS is something you should only do when you really must, and doing it to make modifications of some kind is an exceptionally bad idea. Don't even think about it.
Simply you can't, it's locked out.
