Hi all,
I got a Vaio Pro 13 which I replaced the battery in a while back. I also had another Pro 13 that broke down (I think that the fuse for the screen burned and when I was trying to fix it i shortned something, but ebough about that), so I have two extra batteries for my laptop.
I want to reuse my old batteries. Is there any documentation of which connectors arw which on the batteries? Does anyone have any experiance with this? I'm thinking about maybe using them together as a external battery somehow - if possible.
Any help is much appreciated.
Cheers,
Daniel
First, I'm not a Sony employees
I hope this will help:
https://it.ifixit.com/Guide/Sony+Vaio+Pro+13+Internal+Battery+Replacement/56763
Manolo
Hi Manolo,
Thank you for your response.
However, the replacement is not the issue - I got that covered. What I'm asking is if I can reuse my old internal batteries as external ones. If any one has like a spec sheet of the internal batteries connectors, has any experiance with the batteries more than replacing them.
Cheers,
Daniel
