Hello
I hope someone can help. I have a Sony Vaio VPCEB1Z0E.
I was watching Thomas The Tank Engine on YouTube with my 18 month old son and he kicked the laptop off my lap and the screen cracked when it hit the floor.
I have searched on eBay for "VPCEB1Z0E screen" but the results that come back are for a 15.6" CCFL screen and I think (I may be wrong) I need a 15.5" LED screen. I don't understand how I can type in my model number and not get the correct screen.
Can anyone advise where I can get a replacement screen from?
Thanks in advance
Chris
Hi Chris,
Have a look at the following link - it seems to be the correct screen but contact the company to confirm
Rich
Hi Chris,
Rich
Thanks Rich. That's really helpful!
I've sent them an email and hopefully they will confirm it's the right screen.
Chris
You're welcome Chris, let us know the outcome.
Rich
Hi Rich
I ordered the screen you gave me the link to and it arrived today. I've just fitted it and by some miracle it works!
Thanks for your help! It's much appreciated.
Chris
I'm pleased to have been of help Chris
