Hello,
I'm looking for a replacement screen for an older Sony Vaio with the following specs:
Sony VAIO F Series, model VGN-FW51JF
- 27505068 5001558 -
Service Tag
C602W6D3 or GD3
Model PCG-3J1M
And the screen is a Sharp LQ164M1LA4A
9XR57616
I am asking because I can't seem to find it anywhere, and where they do supposedly advertise it as being available, after a short call or e-mail their answer is in the negative: haven't seen or had one in years. One "support specialist" even asked me if I used Google to search for the screen model...
Even though I switched to a newer model, I find myself still very much attached to that laptop and wish to repair it if possible. In this regard, Sony has provided little to no help whatsoever.
Please let me know if you have any information.
Thank you in advance.
Regards,
Chris
Hi Chris,
welcome to Questions & Answers..:smileyhappy:
All I can suggest is that you contact either Vaio support or one of Sony's authorised repairers to see if they could supply with the part.
To find contact details click on the following link - Vaio Support
Hi Chris,
