Hello can anyone help?
i have dammaged the "b" key on my vgn-fs215m what can i do i had a spare key tryed to replace it unsucessfuly im affraid now the rubber button underneath the plastic face of the key is damaged i dont want to pay lots to replace the key any ideas?
otherwise im resorted to cut and pasteing b's
thanks.
One of the Forum members recently posted a link for nexttronics.com not sure if they could help you?
Sony will send you up to 5 (!) keys for your keyboard. All you need to do is ring VAIO-Link
No idea why just 5 though
Hehe
how do i fit them i already tred to fit a key and was unsucessful the key broke
