Hi, i have a sony vaio fe41e with vista home premium. I've just reinstalled the OS and would like to get some of the programs that were originally on it such as windvd and adobe photoshop elements. Ive created recovery disks and had a look inside them, and found that there are .sny files that might contain these programs(110mb-700mb). Does anyone have an idea on how to install them.
Thanks in advance
I found the solution, using kcap.exe i extracted the.pac files from the recovery disks and had a folder with all my setup files.
Glad you've solved your problem, sorry we missed your post..
