can enybody tell me where i find the dll to download, which identify my vaio as an vaio desktop pc.
Because i have some problems wich ClicktoDVD and DvGate after update these programs. They can´t identify my computer as an sony vaio desktop pc.
Best regards.
Run utils.exe from c:\utils\
If running UTILS.EXE does NOT work, you will have to do a full system recovery which results in the loss of any data sotred on your computer.
Also check if the CD or media you are installing this from is free from errors.
