Hello, I have a new VAIO AW11 note book. I have an annoying problem with the space button. many times when I am writing I push 'space' between the words, but it keeps the words together and afterwards I have to correct everything. It looks like this; "hello, Iam from Holland, theweather isfine today,whatare you going todo?"
Can I make the space button more sensible?
I had this on an a-series a long time back and it was a case of replacing the keyboard as the rubber grommit under the spacebar and metal clip was damaged
Could be the same in your case or it could be dirt/food stuck under it - try and get a air canister and blow into it ... see if it helps - sounds to me it is responsive only in a certain way
Hi pvdp1969,
if your vaio still within warranty i suggest you open a case with Sony support..
