I have a vaio vcg v2m model v series intel r and my c drive is nearly full up but lots left on the d drive, I have moved what i can onto the d drive, how do I allocate more room onto the c drive... does anyone know?
Thanks Steve
Very annoying when Sony and other manufacturers do this - I think they expect customers to automatically know where to store/install things when there are customers out there who are knew to computers!
You can get partition merger tools to merge your C: and 😧 together for instance but it's messy and not always problem free
I assume you have checked around the c: for things you can get rid off? Temp folder for instance gets full up with junk as does temp internet files etc
Hi Steve,
welcome to Club VAIO..
Depending on the disc space occupied by your My Documents folder, a possible quick solution would be to change the default location of your My Documents folder, use the following link to view a guide on the procedure: How to Change the Default Location of the My Documents Folder
