Hello guys and ladies
Recently i reintalled windows 7 on my Vaio pc. When i tried to install the drivers i had some problems some of them are missing or they are not installed correctly ? For example FN Keys, i couldnt find the drivers, also the driver for the " Base System Device "... I downloaded the drivers from the sony website for windows 7. Any ideas how i can solve that kind of problems ?
OS: Windows 7 Home premium 64-bit
System Model: VGN-FW41E_H
Hi @BlackB1rd,
for Fn Keys:
https://www.youtube.com/watch?v=f96C5RllNG8 (Sony® Firmware Extension Parser Device Driver it is SFEP Driver).
For "Base System Device":
http://mikescomputertips.blogspot.it/2011/04/finding-drivers-with-pci-database.html
Manolo
Hello again
The link for the " Base System Device" helped alot.
However, i didnt manage to fix the Fn Keys... i follow the instruction in video but nothing.
After the video from youtube i tried others solutions from the internet and still it doesnt work. Like to check in services , to install the drivers with another order or other drivers with a spesific order.
I found two sony firmware extension parser device driver. the first had exe file but the second it didnt had... How i install the second one ?
Also, i noticed that some key sequence like alt+shift ( keyboard language) , or alt+shift+esc ( task manager ) , or the TAB key doesnt do anything when i type or when i use the browser... I connect the keyboard from my dekstop pc and all worked fine. I checked the settings and are all ok .Driver or Hardware problem ?
Should i return to Vista OS or it can worked with Windows 7.
Thanks for your tine and sorry for my english
Sorry,
heve you installed this driver?:
VAIO Event Service
https://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/Preinstalled_Utilities_4243/VGN-FW41E
My english is not better of yours :smileypraying:.
Manolo
Those driver i have in my pc this moment
http://www.sony.gr/support/el/content/cnt-dwnl/VGN-FW41E/list#os1
