I have just got hold of a docking station VGP-PRFE1 to use with my AR11S.
And unless I am missing something I think its broken!
In theory I should just be able to plug in the power to the docking station then plug the laptop into the DS yes? There was no driver disk so I assume everything is standard?
The funny part is that Vista found a new USB hub and installed drivers for that but the in-use light has never come on and I am not getting any power from the DS to the laptop.
As well as no in-use light I don't get anything showing on Vista that acknowledges the DS has been attached. Which I think is a bad sign in itself!
I was expecting some kind of docking icon to allow me to 'undock'. Or do I need drivers for Vista??
Maybe I am assuming too much that power comes through the DS to the laptop?
Anybody else had a problem with it or am I missing something?
Thanks,
David.
Hi David
Here is a link to the PREF1 manual: PREF1 Manual
Doesn't sound good..
Are you using the notebook power supply or the one supplied with the docking station to power your docking station.?
Hi David
Doesn't sound good..![]()
I would have thought that the light comes on as soon as you plug it in
